On 2001-06-27 09:31:23, willem wrote:
I've downloaded a commandline DOS Freeware utility called wav2mp2 from this site:
http://www.mnsi.net/~jschlic1/
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>dear willem, if you still have wav2mp2 program pls.
send it to my emai address as it is no longer atthe site that you posted or which site cani download it from
Thanks a lot.
The link (http://www.mnsi.net/~jschlic1/) I posted still works. You can download version 1.1 here dated 4th february 2001. The program is actually called wav2mp instead of wav2mp2. Maybe this caused a little confusion.
Regards,
Willem -
Mo,
You can load the wav file into TMPGEnc and then convert it to mp2 as well. If you need assistance, send me an e-mail. Hope this helps.
Regards,
The Daywalker -
I find Toolame works faster than wav2mp2. Also, Toolame can be set up as the audio encoder in TMPG.
Braindrain:
Many people say it is better to use Toolame for MP2 encoding in TMPGEnc. Why is this? Does it produce better quality MP2's than TMPGEnc's built in encoder? Because I want the best sound quality you can get.
(I am using TMPGEnc 12h, audio is MPEG layer 2, 224kbps Joint Stereo)
AP Enterprises Ltd.
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 12:38 -
Convert to M2P
By BuzzStPoint in forum Video ConversionReplies: 4Last Post: 25th Dec 2009, 13:24 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 22:45
