I have roughly 20 videos standing on my laptop that I want to put on DVD so I can watch them on my TV. They are around 400 megs each and in AVI compression... but when I put them on a video DVD (for the TV) they bloat to a 2.5GB each... Therefore I can only put 1 full video per DVD (not really worth it).
Is there anyway to keep roughly the same size as it started (400) and still be able to watch it, or am I stuck burning dozens of DVD?
Thanks in advance
- SnakeDoc
(this is using nero vision)
Sure. Get a player capable of playing DivX/XVid AVIs.
Otherwise, you're going to have to convert. If you're interested in putting multiple videos on a disc, in DVD-Video format, you can use a program like ConvertXToDVD, DVD Flick, etc. However, to fit more videos on a disc, the programs will lower the quality of the videos. From the description you've given, your videos would probably lose quite a bit if you attempted to put all 20 of them on one disc.If cameras add ten pounds, why would people want to eat them? -
If you want reasonable quality then you are restricted to between 2 and 3 hours on a DVD. If you are happy to sacrifice some quality and go to a lower resolution then you can stretch this out to 7 hours at VCD quality.
The bitrate of heavily compressed video (Divx/Xvid/MP4 etc) cannot be compared to mpeg2 (DVD). A general, but not absolute, rule is to expect a 3 - 4 fold increase in size. NeroVision will bloat them even more.
The advice given above - to get a Divx/Xvid capable player - is the best option if this is the format you have most of.Read my blog here.
Not Enough Space in DVD RW Drive
By marnisper in forum Newbie / General discussionsReplies: 5Last Post: 21st Aug 2010, 14:48 -
DVD Rips Taking Up Too Much Space
By vidvidhh in forum Newbie / General discussionsReplies: 18Last Post: 29th Jun 2009, 02:38 -
Explanation of DVD Space Requirements ?
By mbluett in forum Video ConversionReplies: 22Last Post: 4th Mar 2009, 14:35 -
How to burn DVD without enough free space in C:
By LUCAS67 in forum Newbie / General discussionsReplies: 5Last Post: 26th Mar 2008, 14:30 -
Is VCD/DVD disc space limited by time, or space?
By pingosimon in forum MacReplies: 6Last Post: 14th Jul 2007, 20:55
