  1. I have 5divx avi files, each of 1hour, so its 5hours in total. They are not dvd quality but i want to fit them in 1dvd. What do i do?
    Heres what ive done sofar but im stuck. I put them in Toast, in the video section, and from Toast i burned to the HDisk as BIN and Cue file. Can i burn that BIN&CUE file (7GB) to a DVD5 disk? I need an app that will burn and shrink those 7gb to the 4gb thats needed for a DVD5 disk!
    Any ideas?
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    In Toast, select the Copy tab. In the left drawer, under Formats, select Image File (not Bin/Cue Files!). Below that, check the Fit-to-DVD video compression checkbox. Drag-and-drop your .bin file on the main Toast window.
    Burn or Save as Disc Image to create a DVD-5 disc.
  3. Wow thanx so mutch, now that seemed like a very good solution! Ill try it on tomorow! Wow
