Hello everyone need a little help, any tips appreciated...
I recently acquired a reasonable spec (pentium 4 2.6ghz, 1 gig ram, geforce 6200 gfx card, win xp pro) pc and thought I would put it in the lounge, hooked up to my 32-inch lcd tv. I have all my video files on another pc upstairs (pretty high spec) so thought I'd share the files and play videos over the network. I could access the files and they initially seemed to play ok, but kept pausing every 30 seconds or so (audio and video) just stuttered for a fraction of a second, then carried on. Just enough to be annoyingly unwatchable. Same thing happened with 3 media players on default settings (media player classic, vlc media player and wmp11).
Are there some settings I need to tweak, eg buffering the file as it plays...or is there a different media player designed for the purpose? Is my network just not up to the job (i use a belkin 54mbps router, lounge pc connected with cable, upstairs wireless). The data transfer over the system seems good, as my 10mbps broadband works reliably at full speed upstairs over wireless connection.
Finally assuming I can solve the above problem and keep the 2nd pc in the lounge, is the processor good enough to decode this new H.264/MPEG-4 AVC format as I believe this is very processor heavy
Thanks!
capture the video and share it over network
By zamansoomro in forum Newbie / General discussionsReplies: 0Last Post: 17th Apr 2011, 13:35 -
looking for some network video camera
By George2 in forum Newbie / General discussionsReplies: 1Last Post: 7th May 2009, 07:37 -
Why doesn't sound work when playing through local network?
By Obamargarine in forum Software PlayingReplies: 1Last Post: 23rd Feb 2009, 13:39 -
Network printer on separate network?
By Lucifers_Ghost in forum ComputerReplies: 7Last Post: 5th Dec 2008, 13:52 -
Nero Showtime playing from network folder ?
By Ian Huxley in forum Software PlayingReplies: 1Last Post: 1st Jun 2007, 12:40
