I m using nero 6 to burn DVD and after burning file avi to dvd , i tried it on dvd player but after few seconds, everything stop. I tried to burn different movie but the same thing happened. Need Advices from u guys . Thx
Results 1 to 11 of 11
So you used NeroVision to convert the avi file, then burned it to DVD.
1. Did you test the DVD NeroVision created to see if it works from your HDD, before burning ?
2. What brand of media did you use ? What is the media ID ?
3. Have you tried burning with imgburn - a far superior DVD Video burning application ?Read my blog here.
Yes use IMGBurn, it has test mode before burning..as guns asked what media? But IMO, I would scratch/not use NV for avi to DVD, try DVDFlick or ConvertxtoDVD, better solutions, again IMO.....good luck!
" Who needs Google, my wife knows everything" -
i cant use nerovision to convert avi to dvd . I use winavi, it also has preview while converting
T_T so what can i do ? i have to use some software to convert avi to dvd and then burn to dvd by nero cuz i dont want to uninstall nero. T-T
Why not ? Most of Nero is un-necessary.
Putting Nero to one side, you could try
ConvertXtoDVD (payware - arguably best of the one-click-wonders)
DVD Flick (free)
FAVC (free)
Always burn DVD Video with Imgburn in preference to Nero. Much better tool.Read my blog here.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
Complex problem, extra some chpts from 2 dvd and combine into 1 dvd + menu
By Shihtzu88 in forum Authoring (DVD)Replies: 1Last Post: 23rd May 2009, 09:09 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
Problem rendering DVD and menu with Ulead DVD Movie Factory 6
By Jeff_NJ in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 04:26 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 22:37
