hi there.
I am having a problem converting movies with subtitles, i already converted the subtitle from .srt to .sup and crash when goes convert, tryed without subtitles and worked...need some help, use subtitles is essencial for me
here goes the changelog
I am using Vista Ultima 64bits and the last version of SVCD2DVD, and already run the program as administrator.Version: SVCD2DVD 2.5 DEMO
Build: 2.5.2738.0
Type: System.DllNotFoundException
Source: SVCD2DVD
Message: Unable to load DLL 'supmuxer.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
InnerException:
StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.SupMux(xc76139 390a97debb xd2637df501625a82, x81974c36d7fdf1e1 xb4ee5c1758e9e983, Int32 xdc4f66b5011a3c9d, String[] x738d70b20493db82)
at x3284ccece41ee22b.xd3764d4f1e921081.x083f56b29aec9 17d(xece14591aa1abb99 x50afe96f7df19242)
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
	For some reason the dll was missing from the release. Can you redownload and retry please? SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
	It worked, thank you
 But has appeared another problem... after convert i've burned the movie at 16x, when i play on the dvd player the movie crashed at the first 24 seconds tryed on pc and worked. after convert i've burned the movie at 16x, when i play on the dvd player the movie crashed at the first 24 seconds tryed on pc and worked.
 Then i burned the same movie at 4x, and on the dvd player the movie crashed at the same 24seconds...could be some kind of subtitle problem, because it occurs when the first person talks on the movie.
 My DVD player is fine is a Sony and plays divx, never had this kind of problem...
  DVD Lab Pro - New OS, same location of files = Subtitle generation = crashBy Paker in forum Authoring (DVD)Replies: 5Last Post: 18th Sep 2010, 09:56
  Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 18:03
  SVCD2DVD crash on xp 64 bitsBy alkirah in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 5th Jan 2009, 09:17
  Fatal Error on Startup SVCD2DVD 2.5 (CRASH)By jenevans33 in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 16th Mar 2008, 11:06
  Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASHBy maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 01:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
