Quick question, I am burning off a .avi to dvd and was wondering under options should i have the smaple format set to automatic, progressive or interlaced top first/bottom first?
Leave that one on auto; you can find what NVE will do by clicking on details. I usually only change the quality settings, "high quality bitrate" and "VBR High quality". It seems NVE doesn't re-encode source material that is already DVD compliant, that way (you can tell by the audio and video percentage reported in the details and by the smart buffer icon).
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
Nero Vision 5 Help
By luckyboym in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2008, 00:47 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Vision 5
By marioval in forum Authoring (DVD)Replies: 0Last Post: 11th Oct 2007, 13:45 -
Chapters using Nero Vision?
By aelfheah in forum Authoring (DVD)Replies: 4Last Post: 8th Jun 2007, 11:40
