Hi,
I cannot find any player can display the subtitle inside Divx files except Divx Player. but I have audio problem with Divx Player, so I try to find another one. Any suggestions?
Results 1 to 10 of 10
Thank you, KM is good player but still won't work. WMP can display subtitles if Divx6 is installed but the quality is worse than it displayed in Divx player itself. MPC/VLC/Zoom/KM player won't display subtitle.
It is very strange that Divx player outputs very-streatched AC3 audio, WMP, MPC and other player gives good audio output. I have AC3-ACM codec installed and AC3filter. -
Sorry for wrong info.
I didn't know that this is about xsubs. I've never encountered those. -
Problem is that I don't think anything other than DivX6 handles xsubs, so you would be looking at a similar situation to what you get in WMP no matter what player you use. Perhaps DivX has some kind of gaussian blur type setting for subtitles? Since xsubs are bitmap based, they will never look quite as good as softsubs using vector based fonts since these can scale to any resolution without quality loss.
Hi.
I am looking for a Divx player that would handle .srt or .idx/sub, because all of a sudden Winamp quit playing Dixv video. While I am trying to fix it (I have described the problem in a seperate post), I have been using Divx 6 player to watch movies. However, according to the message from celtic_druid, Divx 6 should handle subtitles. Since mine does not, do I have a problem? Please, let me know. Thank you. -
Does it come with their burning package or is available separately? Thank you.
DVD Player that plays Divx (.avi) and (.mp4) files ?
By keith knip in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Oct 2011, 15:12 -
mpg plays badly in divx dvd player
By ssalim in forum Video ConversionReplies: 25Last Post: 3rd Apr 2009, 11:39 -
So I bought a Philips DVD player that plays DivX files, but have a problem.
By quitearush in forum DVD & Blu-ray PlayersReplies: 5Last Post: 13th Jan 2008, 03:25 -
Standalone Player plays only 33 mins of the resulting DivX DVD
By penguin74 in forum DVD RippingReplies: 8Last Post: 30th Oct 2007, 18:25 -
.divx with subtiltle playing problem
By qknet in forum Software PlayingReplies: 6Last Post: 24th May 2007, 04:05
