Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
  1. When I want to burn a dvd from a movie file I use nero vision 4 but i always has to do some "coding" thing before it burns. Is there a faster way to burn. Other softwares?
    Apr 2004
    Miskatonic U
    If the file is not DVD compliant then it has to be made compliant, and authored for DVD - the "coding" thing. There isn't much you can do about it. You can try to find a faster encoder - ConvertXtoDVD might be a little faster - or you can get yourself a DVD player that plays back Xvid/Divx content without conversion. You may still have files that need converting, and for those you will have to wait. The only real way to speed up the conversion process substantially is to
    a) stop downloading files and buy DVDs instead
    b) buy the fastest computer you can find
    Read my blog here.
    Apr 2007
    ConvertXtoDVD is nice because it's all in one big step. Just put your files on and let it sit. You could go to work/school and come back and your DVD is finished. It's a really nice program.
