Well I have worked on this problem for like 4 hours now. Im going crazy trying to fix it. When I put in a dvd and use WinDVD to play it, the picture is in very bad frames and is overal very very slow. The sound jitters aswell. Now I know its not WinDVD's fault because when I play a dvd from the hard drive it is perfect.
I know my setup is very capable:
Core 2 e2160
X1950 Pro
Gigabyte DS3
2GB ddr2 800
LG GSA-4163
Do other players do the same thing with a DVD? Try VLC player. It uses it own codecs, so it may give you a sign that your installed codecs have a problem.
Other thing to try is to see if your DVD burner/player is in PIO mode.
That should give you a start.To check DMA/PIO mode within Windows:
Control Panel>System>Hardware>Device Manager>IDE ATA/ATAPI controllers.
From there, right click on one of the channels and choose 'Properties>Advanced Settings'. All drives should be DMA mode. The 'Current Transfer Mode' for Hard drives is usually DMA 4-6 and DVD burners DMA 2-4, DVD ROMs usually DMA 2. If you see any in PIO mode, that can slow things down.
Changing them back may be easy or complicated. First see if you can change them in that window. If not, I usually uninstall the channel the drive is on and let the OS reinstall it. This will usually take a reboot. This will not damage any files on the computer.
And welcome to our forums.
My dad uninstalled the motherboard and video card drivers. It seems to be better. Still not 100% but is like alot different. Before you could hear the menues but the picture took along time to come in and would be like still pictures. Like 5 frame per 10secs. Now its still weird, well see once all the drivers are installed again.
Both VLC and WinDVD play about the same. It is on Ultra-DMA setting.
Thank You for the welcom and I appreciate the help. -
With Vista, video and audio drivers are a problem with some motherboards. Check the download page on your motherboards website. You might also try a driver from both the audio chipsets websites and the video cards website. ATI and Nvidia drivers that come with the motherboard may not be up to date or completely compatible with Vista.
I had better luck with the video drivers on the Vista OS disc than I did from the motherboard disc. Even the ones on the motherboard website were not as good as the ones directly from Nvidia.
Apparently when a motherboard is listed as 'Vista Certified' by the manufacturer, it doesn't seem to always mean it will come with the best drivers.
At least mine wasn't.
Even with W2000 or XP, I would check for the latest drivers from the manufacturers sites. But in a few cases, the slightly older drivers may work better. It pays to look for user forums specific to the video and audio cards or chipsets to see what they might recommend.
Well a reinstall of Windows fixed the problem. Thank You everyone who help I do appreciate it.
DVD Architect Studio 5.0 plays my files at double speed and no sound
By MCnDaHouse in forum Authoring (Blu-ray)Replies: 2Last Post: 3rd Feb 2012, 11:22 -
What is the best way to author a dvd...AKA GET RID OF THE JITTERS!
By burrowsfan in forum Newbie / General discussionsReplies: 12Last Post: 20th Feb 2009, 13:57 -
No sound plays on completed DVD
By Zippity in forum AudioReplies: 4Last Post: 27th Nov 2008, 16:39 -
Windows Media Player plays DVD without sound
By anindyanuri in forum AudioReplies: 6Last Post: 30th Nov 2007, 13:07 -
editer shows 'no sound', mpg plays with sound
By oldvideote in forum EditingReplies: 3Last Post: 7th Jul 2007, 09:01
