whenever i try to save what i've cropped it says:
cannot initialize smart rendering: no video codec is selected for compression
I also haven't a clue as to how I can paste an mp3 onto the cropped up avi.
I posted about this a couple of months ago, failed but thought i'd try again. sorry for being repetitive, but i seem to have devolutionized; before i used to know how to crop the avis but couldnt stick mp3s on them, for instance, among other tragicomic things. anyway, like the fools and horses guy, him who dares, wins, so i'd very much appreciate your help on this matter.
i am not you am not i am not you am not i am not you am not i am not you am not i am not you.
Originally Posted by jagabo
how to get an mp3 to play over the stuff i've cropped?
anyone?i am not you am not i am not you am not i am not you am not i am not you am not i am not you. -
Originally Posted by pondleaping
Or in VirtualDub: Convert your MP3 to an uncompressed WAV file the import the WAV with Audio -> WAV Audio. -
When you use the crop filter then you need to recompress the whole video using Full Processing mode. Smart render will not work for this.
As stated above, you must either create a wave file from your MP3 to use with Virtualdub and recompress to MP3 or use VirtualdubMod to insert the MP3 file. -
nah by crop i mean the difference in cut assistant that says cut and crop, with the former you cut away from the file, with crop you get a bunch of scenes you want.
anyway, thanks guys your distinction between virtualdubmod and virtualdub may be very helpful, im downloading the former right away.i am not you am not i am not you am not i am not you am not i am not you am not i am not you. -
To most around here "crop" means to cut off part of the frame. So you might crop a 640x480 video down to 640x464 by removing the bottom 16 scanlines because there's nothing but VHS head switching noise down there. This type of operation requires decompressing the source and recompressing it.
What you're doing is cutting or trimming away unwanted frames. This may or may not require reencoding depending on where you cut.
VirtualDubMod does not have Smart Rendering like the most recent beta versions of VirtualDub. Any retained segment in VirtualDubMod in Direct Stream Copy mode has to start on a keyframe.
Cut Assistant not working the way it's supposed to
By jeanmarc in forum EditingReplies: 3Last Post: 3rd Dec 2010, 04:47 -
HP Product Assistant
By jyeh74 in forum ComputerReplies: 1Last Post: 3rd Jul 2009, 18:17 -
automatic or batch processing in Cut Assistant: possible?
By cbarduck in forum EditingReplies: 0Last Post: 9th Feb 2009, 06:11 -
Can remote assistant work between XP and Vista?
By yoda313 in forum ComputerReplies: 6Last Post: 7th Jan 2009, 17:53 -
How can I associate cut assistant with virtualdubmod
By pondleaping in forum EditingReplies: 3Last Post: 2nd Aug 2007, 09:06
