I've just bought a Canon Pima MP600, and bought some Datawrite 8x General Purpose Printable Surface DVD's So far I've had 10 out of 10 coasters the one thing the all have in common is there's a concentric ring around the outside of the disc that looks like it hasn't being burnt.
I use Datawrite because they burn & play 100% on my desktop & DVD Players
My DVD Recorder is a SONY: DW-Q28A - (Firm ware KYS1) I have checked and my current Firmware supports the dye on these DVD's CMC.MAG.AE1
Nero Disc Info:
Nero CD-DVD Speed: Disc Info
Basic Information
Disc type: : DVD-R
Book Type : DVD-R
Manufacturer: : CMC
MID : CMC MAG. AE1
Write speeds: : 4 X - 6 X - 8 X
Blank Capacity : 4.38 GB
: 4489 MB
: 4707319808 bytes
Extended Information
Layers : 1
Usage : General
Copyright protection : n/a
Recorder information : recorded with SONY DW-Q28A KYS1
Disc Status : Closed
Raw Data
Pre-recorded Information in Lead-in (0Eh)
0000 - 01 40 C1 FD 9E D8 52 00 02 55 0D 0E 88 9A 80 00 - .@....R..U......
0010 - 03 43 4D 43 20 4D 41 00 04 47 2E 20 41 45 31 00 - .CMC.MA..G..AE1.
0020 - 05 88 80 00 00 00 02 00 01 00 00 00 D9 8B 41 7E - ..............A~
0030 - 88 00 47 7E AC 74 05 00 60 75 05 00 AC D5 41 7E - ..G~.t..`u....A~
0040 - 59 D5 41 7E 20 00 00 00 A2 03 01 00 60 72 82 00 - Y.A~........`r..
0050 - 00 00 00 00 01 00 00 00 78 75 05 00 00 00 15 00 - ........xu......
0060 - 32 07 91 7C 0B 00 00 00 98 08 15 00 00 00 15 00 - 2..|............
When I do a Nero Disc Scan it stops scanning at: 85% of the disc
Progress: 85.7%
Position: 3824 GB
Condition: 99% Good
My first thought is this batch is a faulty batch.
Any other Idea's ????
If you have used these before with no problem i'd say you have a bad batch. There is a possibility your burner is going bad. But thats probably not it. Are you able to burn data dvd's with no problem. I recomend you try a program called imgburn also. It's free. I have taken nero off my computers and haven't found that i miss it for anything. Far bettter for burning then nero.
Suggest trying different media (I only recommend TY and Verbatim) to eliminate burner as suspect. Do a CD/DVDspeed discan and quality scan (if your burner allows) to check burn. I second the motion about Imgburn, never liked Nero.
I love children, girl children... about 16-40
W.C. Fields -
Batches are thousands and thousands of discs in size. CMC is mostly nothing but "bad batches" with a pretty miserable reputation on producing good burns.Originally Posted by buttzilla
Use better discs. www.nomorecoasters.comWant my help? Ask here! (not via PM!)
Thank's for your replies & idea's.
I choose Datawrite because they had being 100% relaible for me in the past, so natually when I was looking for a Printable DVD I choose Datawrite, I had never used Datawrite Printable DVD's before. I normal use Datawrite Titanium DVD-R's.
I've tried buring with CyberLink PowerDVD Copy and download & tried IMG Burn with no luck still get the same results, 15 out of 15 failures so far, I'm going to attempt to return them as faulty. and buy another make.
I've managed 3 pefect burn's with my normal Datawritw Titanium DVD-R's so it's not my writer.
Thank's for your help......
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
problem with video disc burning
By rahulcb in forum Newbie / General discussionsReplies: 3Last Post: 6th Mar 2010, 01:49 -
faulty DVD-R will not finalize
By joecass in forum DVD & Blu-ray RecordersReplies: 19Last Post: 10th Nov 2009, 19:51 -
After burning, DVD disc was changed to CD
By coody in forum ComputerReplies: 0Last Post: 22nd Sep 2009, 22:16 -
Faulty wmv3 (9) codec problem
By Darius_bd in forum Newbie / General discussionsReplies: 6Last Post: 26th Dec 2008, 18:30
