I would like to convert some mkvs to dvd format files and burn them onto a dvd. I've been successful with everything so far but I just have one question: Is it possible to add .ass subtitles to dvds? I prefer not to change ass to srt or something more normal, because I want to keep the original styles and positions of the subtitles.
Any advice would be appreciated
Results 1 to 11 of 11
AnonymousGuest
No.
Nor is there a magical easy conversion of ass to dvd subs.
You could go from ass to srt to subtitle creator, and try manually recreating styles and
positionings, use sup to author.
Could be a pig of a job if we're talking exotic subs.
Could mean using an authoring app different to your current.
I'm usually dead against hardcoding subs, but this is one
of the cases where it makes a bit of sense
gl -
Thanks, but after I downloaded the .net framework, it won't install properly so I can't use it.Originally Posted by romi7519
In that link you gave me it said other things you needed, one of which was .net framework. I can't install it, and when I click the icon like you say, there's an error which is not having the right framework.
Yes I've already downloaded that. BUT it won't install properly, leaving me SOL.
This is hijacking if ever I've seen it.
You should start a new thread with your specific problems.
Why can't you install net framework?
You should try tackling that.
Error messages and what not.
What's in the mkvs?
Several options.
You could try these apps:
Tmpg Xpress, Convertx, Avi2dvd, Super.
Or try frameserving with avisynth to an mpeg2 encoder, for more complicated.
guides
https://www.videohelp.com/guides?searchtext=&tools=&madeby=&formatconversionselect=MKV+...or+List+Guides
gl
How to Convert MKV with ASS Subtitles to DVD - Solved!
By rickydavao in forum Video ConversionReplies: 10Last Post: 22nd Nov 2010, 21:51 -
Not sure if it goes here. Convert MP4 and MKV to DVD with subtitles.
By The_Forastero in forum Video ConversionReplies: 2Last Post: 15th Jun 2010, 14:33 -
convert mkv with subtitles to ps3
By karatechop in forum SubtitleReplies: 1Last Post: 30th Dec 2009, 07:29 -
Convert from MKV and keep subtitles / audio.
By Alchey in forum Video ConversionReplies: 1Last Post: 10th Oct 2009, 03:45 -
Convert mkv with subtitles
By redneon in forum ffmpegX general discussionReplies: 4Last Post: 11th Mar 2008, 16:12
