Hello,
I got a video file and it edited the file, it was only a 12 min clip, its in DV format, now I tried to burn this to DVD and It wont fit, its saying its to big, on final cut, what do i need to export my editing to, so i can burn on a regular dvd and its normal...
What is the process...
Ed
	Final Cut Pro has two favored OUTPUT Choices for DVD
 one is the built in COMPRESSOR
 the other is using a third party MPEG-2 plugin package (like digigami)
 you make MPEG-2 output with companion Audio (ac3, mpeg or pcm)
 if you use a plug in will follow the Quick Time export and show up there
	or export DV format and use iDVD for a quick DVD if you don't want to learn all the pro tools..
 Okay, I want to use the Pro Tools, but what are they, how .. etc...
 I can export to DV, but its too big, lets then 12 min get on 1 dvd, so what can i do to compress this to dvd without lossing quality...
 ed
	read this:
 https://www.videohelp.com/author
 You'll need to compress it to MPEG2 before putting it on DVD.
 Do you have DVD Studio Pro? Use that? or iDVD Read the manuals and let us know when you have a problem.
 Here's a list of tools but they're PC: DVD-Lab is great for the money
 https://www.videohelp.com/tools/sections/authoring-dvd
  Just want the video clip using DVD-lab PRO 2By WTRanger in forum Newbie / General discussionsReplies: 13Last Post: 29th Oct 2010, 06:18
  FinalCut Pro settings for YouTube work & export?By MikeBell in forum Video Streaming DownloadingReplies: 1Last Post: 30th Nov 2008, 11:37
  logitech pro 9000 captured video to premiere pro CS3?By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 17:27
  Turn off bitpacking in FinalCut Pro?By Routine in forum MacReplies: 2Last Post: 13th Jun 2008, 09:42
  Newbies first post - FInalcut + what?By fontenele in forum Newbie / General discussionsReplies: 0Last Post: 7th May 2008, 18:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
