So, I've a video in two *.avi files (part1.avi & part2.avi). I tried to convert it to a DVD with DVD flick - loaded them in one title and converted. DVD flick didn'd report any errors, but in the resulting DVD only the first avi was presented. What to do?
I don't use DVD Flick, but at a guess, it has created two titles and not provided continuous playback when authored. If you try playing it back in a software player you will probably be able to choose the second title, just to prove it's there.
Choices :
1. Look for something in DVD Flick that provides sequential playback of multiple titles. Many authoring tools have them.
2. Change authoring tool to something that does support what you are trying to do, if DVD Flick cannot.
3. Join the two avi files together before you author. Even if you can get sequential playback, there is a very high chance that there will be a brief pause between the titles - about as long as a layer change on a DL disc. Joining beforehand removes this pause. I would suggest AVI Demux to attempt the join, and to test it after joining for audio sync issues in the second half before converting and authoring for DVD.Read my blog here.
no, it haven't encoded the second part at all! I have checked all the *.vob in resulting DVD directory and all they were for the first part
thank you, but it's not the first time I m using DVD Flick for such a task, so I know that it can perform such task and the problem is only in this contrete movie. And I'd want to continue to use DVD Flick for such task, not merging avis before. Because this method really works in most situations.
Converting AVI to DVD using DVD Flick: low quality result
By e2p in forum Video ConversionReplies: 13Last Post: 28th Oct 2010, 11:50 -
Merge video files in DVD Flick?
By morgle in forum EditingReplies: 6Last Post: 13th Aug 2010, 11:28 -
DVD FLICK Bug? 1.0.3.6 version won't encode mpeg2 files properly...??
By bahjan in forum Authoring (DVD)Replies: 0Last Post: 21st Jan 2010, 07:40 -
DVD Flick title problems
By friedlady in forum Newbie / General discussionsReplies: 4Last Post: 19th Mar 2008, 18:39 -
Conversion tool for Real Media files to avi to burn to dvd
By loninappleton in forum Video ConversionReplies: 17Last Post: 29th May 2007, 14:30
