Hey, I'm fairly new to converting audio / video and dvd authoring it. I currently have a series of .ogm that I'd like to remove one stream of audio from. When I use OGMtoAVI it plays both audio streams at once when it converts and I don't want to hear the sound all garbled up (it plays the japanese and english sound at the same time, making it sound like crap.) Is there anything I can run these files through before OGMtoAVI to disable one audio stream? I tried VDubMod, but I don't know if I'm going about it the right way or not.. I don't want to spend 45 minutes per episode for 25 episodes. I'd like the quickest possible route, and one that supports batching if possible.
Any help would be greatly appreciated as I really want to convert this series so I can get to DVD Authoring it! Thanks again.
Try convert with AllToAVI, I guess you can specify audio track in it.
Or else try remove the audio from the ogg with ogmdemuxer.
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 23:42 -
Multi-stream OGM to hard subbed AVI
By bizzybody in forum Newbie / General discussionsReplies: 4Last Post: 26th Apr 2009, 00:33 -
Some questions about the Transport Stream.
By Talayero in forum Video ConversionReplies: 4Last Post: 22nd Jul 2008, 19:42 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 04:27 -
complete audio removal
By pabloj240 in forum AudioReplies: 1Last Post: 23rd Jul 2007, 01:51
