hi
i'm not sure what section this should be in, so i'll ask here
i installed the vlc player and it's playing flv files well, until i click on the timeline, say to jump further in the video. Then the player closes the video and i can only see the buttons and menus
The actual videoscreen got closed automatically.
Is this normal or do i have to do something special here?
I know u can click, for example, in windows media player anywhere u want and the videofile will play on from where you clicked.
Got me mindboggled this one...
so thx to all who can help!
cheers
Do all flv files do that? If so, probably a quirk with VLC. It uses a lot of CPU power to decode some formats and may not be the the most efficient with some file types. I have seen the same problem with other types of files with most any player, and then it's usually a fault of the file. VLC will play corrupted files, so it's not always easy to tell if the file has a problem.
Are you using a newer version? 8.6c is the latest stable version.
BTW, if in doubt, Newbie/General is always a good place to post.
yes all flv files do it with version 8.6c
allthough, if fast forwarded up to 8x, they look ok
only jump to-clicking locks up the player
thx for the help -
You can use mouse gestures to control the interface, at least in the Mac version.
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 07:28 -
display size between windows media player and VLC player
By kool_k in forum Software PlayingReplies: 4Last Post: 6th Aug 2011, 15:18 -
Better media player than VLC?
By meneedit in forum Software PlayingReplies: 5Last Post: 16th Nov 2010, 07:32 -
vlc media player
By natty in forum Newbie / General discussionsReplies: 5Last Post: 30th Aug 2010, 13:10 -
vlc media player question
By Adventure Man in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2009, 17:20
