Hello
I posted in the newbie conversion section but it's there it must be posted.
My original post :
Hello,
I've got a problem when I encode an avi file to mp4 with MeGui.
I think the problem is with avisynth because the problem is the same when I encode with xvid, but it'm not sure at all.
The encoding finish well but when I play the mp4, some parts of the file was cut. And at the place of the lacking parts there're the film that repeats itself.
I uploaded a exemple of video files there : http://dl.free.fr/b3KUSklGp/avi_mp4.7z (12mb)
You'll find a cut of the avi I'm trying to convert to mp4, and the mp4 I get after the encoding.
Very strange isn't it ?
All the options I choosed in MeGui are thoses by default. I'm using the lastest version 0.2.4.1041.
Since that, I realised that the problem come from the script avisynth. I use DirectShowSource() in the script and I've got the problem I mentioned when I do this. When I try AVISource() it doesn't work at all.
It this post, someone has already experiment this problem :
https://www.videohelp.com/forum/archive/directshowsource-reliability-problems-for-dv-de...h-t330213.html
I think I need the right codec to use AVISource() but I havn't.
In virtualdub the video play well and the decompressor is Internal DV Decoder (DVSD).
So, my question is, how to make DirectShowSource() works when I use this function in avisynth to encode my video in MP4 ?
Thanks for your help
Sekaiji
AVISoure() requires a VFW based DV decoder. Try Panasonic DV codec, Cedocida, Canopus DV codec. Or try one of the latest beta versions of VirtualDub which has its own DV decoder built in.
Nice! I'll have to remember that if I ever have the same problem.Originally Posted by sekaiji
Mp4 inside Virtualdub (DirectShowSource is refusing)
By jairovital in forum EditingReplies: 21Last Post: 1st Feb 2012, 19:25 -
loop mp4 or avi locally so will play on mp4 player - ?
By marinebc11 in forum Video ConversionReplies: 3Last Post: 3rd Oct 2010, 21:24 -
Best software to convert VOB to mp4 or AVI, or AVI to MP4?
By 80zforever in forum DVD RippingReplies: 7Last Post: 18th May 2010, 13:32 -
Need help with AutoGk - DirectShowSource
By patrickj0781 in forum Video ConversionReplies: 0Last Post: 22nd Feb 2010, 11:23 -
avi to mp4 with MeGui prob...
By sekaiji in forum Video ConversionReplies: 2Last Post: 29th Jun 2007, 17:48
