I recently built a new PC and everything on it was working fine. However within the last week or so, my internal DVD burner (I/O Magic w. Lightscribe) stopped recognizing discs (blank, CD, DVD, install discs, anything) all together. The drive shows up under My Computer, but cannot be clicked. If you click it, the cursor turns into an hourglass for a minute or so and then back into a cursor. (Left or right clicking). Sometimes when you click it, it tells you that the drive cannot be accessed because of an I/O Device Error. Additionally, I have an external JVC burn station for our HDD Camcorder. That also functions as an external USB 2.0 DVD drive. That one will also no longer read any discs. However, that one you can click, or right-click. When I review the properties it says that the device is enabled and working properly.
So I tried to replace the I/O Magic drive with a Sony DRU-830A. That drive also reacts the same was as the original I/O Magic drive.
Thus far, I have tried a new IDE cable.
I have gone through Miscrosoft support at http://support.microsoft.com/kb/891894 and tried the fix there, with no luck.
I've shut down, detached the drive, rebooted, shut down, reattached the drive.
I've cleaned my registry.
I a running Norton Antivirus 2002 which finds no viruses.
The only thing I haven't done is reinstall Windows which I would like to avoid.
Any ideas?
Results 1 to 11 of 11
What does Control Panel/System/Hardware/Device Manager say about your drive?
The device is enabled and "working properly."
Bus Number 0, Target ID 0, LUN 0 -
You could try deleting your IDE channels from Device Manager, rebooting and letting XP re-acquire them.
I'm currently doing a repair installation of XP, but I'll try that after. I don't think I've done that yet.
are the drivers for your motherboard and IDE / SATA controller up to date, working correctly and properly installed (if at all)?
the fact that the external drive is playing up also does suggest some bigger force at work however, as USB drives aren't subject to IDE channels or even any drivers more complex than one to chuck data down the cable and get it back as well
-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more! -
Well after the repair install the whole thing just went screwy so I guess I am gonna have to wipe it and start again. I was hoping to avoid this endless loading of drivers, but no joy.
That recognition problem appears more and more.
Most of them could be eliminated by uninstalling tools like Alcohol and DaemonTools, aswell as uninstalling the ide drivers (updating too!) and deletng the upper/lower filters.*** Now that you have read me, do some other things. *** -
Just been out to repair one where device was seen by bios and pc , yet nothing happens when tray button is accessed , or clicked on in windows explorer .
Shut system down , opened case , swapped power connector , and its back to normal .
You see something new every day .
External dvd burners can draw upto 2amps ... enough to overload the usb , and cause major issues .
Make sure it use's its own power supply .
It is possible to have a system device appear to be working in system , yet device has a fault .
I once overloaded the usb2 port , windows said it had been reset , yet video recording was choppy via usb2 from then on ... 6 months later the video card died .
Apic , which controls power management had been compromised ... new motherboard time . -
I just broke down and reinstalled Windows and now everything works fine. Strangest problem. I tried everything on the planet I could think of, and I posted in several different support forums. Found a few people with the same problem but no one could fix it. Ah well. Thanks for the ideas.
sorry i missed the original post. most of the time this is the fix.
http://support.microsoft.com/kb/314060
take a note for next time as it may happen again after installing/uninstalling cd/dvd burning software.--
Computer wonīt recognize DVD disk
By dexter30 in forum MediaReplies: 10Last Post: 4th Sep 2010, 15:52 -
drive won't recognize 8.5gb discs (udf?)
By aerogurl in forum MediaReplies: 29Last Post: 13th Feb 2010, 13:45 -
Burner Won't Recognize Blank DVD-R Discs
By ddowden1 in forum DVD & Blu-ray WritersReplies: 11Last Post: 23rd Aug 2009, 07:52 -
Software fails to recognize DVD-RW discs
By Mummyscurse in forum DVD & Blu-ray RecordersReplies: 8Last Post: 24th Oct 2008, 17:07 -
Sonic won't recognize DVD, computer does ...
By LittleQueenie in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2007, 14:06
