I am looking for video editing software that has some transitions (fade in, out, etc) effects (slow mo, etc), editable titles, voice track, music track...
Would also like something that accepts a wide variety of formats. Although I could convert before importing...does that affect quality??
I am using windows Vista and will have a system with plenty of power (4 gig mem, super fast processor).
Is there something out there for free that can get me in the door? What's the easiest to learn?
Right now, I am doing mostly basic stuff, but find WMM very limiting. I have tried Pinnacle before using Vista, but the program crashed, froze...basically sucked!
Anybody got some suggestions?
I was going to suggest Adobe Premiere Elements for ease until you mentioned multi-format. What do you mean by that? If your source is mostly camcorder and TV tuner then look at ULead Video Studio.
I like Virtualdub as a format converter but not as an editor. -
You don't really give a lot of info so I'm going to assume we're talking digital video.
As far as "free" is concerned, have a look at Avid Free DV. If you're up for some learning, you could also go with virtualdub / avisynth.
I ended up paying for something and using tools from videohelp periodically for peculiar tasks. I downloaded and tried out Adobe Premiere Elements and Vegas Movie Studio Platinum + DVD.
I ended up buying Vegas Movie Studio and I've been very happy with it. -
I think you're after something like Adobe After Effects.
It's not free. -
I wouldn't call Adobe After Effects easy to learn. And it isn't multi-format friendly.Originally Posted by spanky123
You're right - missed the 'newbie' part. My bad!!!Originally Posted by edDV
Advice for simple, free video-editing software for a newbie
By belltown in forum Newbie / General discussionsReplies: 3Last Post: 4th Sep 2011, 22:25 -
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29 -
Newbie to HD Video editing. Please Help!
By kaylis_flock in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 4th Nov 2010, 08:25 -
I want to capture,edit,and burn to VCD or DVD a few dozen old VHS-C
By rivrbyte in forum EditingReplies: 1Last Post: 25th Feb 2010, 14:23 -
Newbie to video editing needs help
By bilekbp in forum Newbie / General discussionsReplies: 2Last Post: 21st Mar 2008, 18:24
