I have used this program before with no problem, but I had to wipe my hard drive and reinstall everything.
I installed DVDAuthor .06.14 and then installed the gui 1.013
When I open a menu to add buttons I get a message stating I need an Mpeg2 direct show filter. This makes no sense as I have PowerDVD installed.
Sometimes when I open a menu I get a divide by 0 error instead and the program closes.
if you have avisynth installed, go to the 'tools' menu, and select 'use alternate preview decoder'.
You will need to have avisynth installed, if you don't already.
www.avisynth.org -
It is probably some improperly registered components. As long as you have avisynth installed, i recommend the 'alternate decoder', as it is much more precise.
Just being curious, did you select a full install, or just a regular (for DVDAuthorGUI)? -
I left out the active x component and the other optional one the first time then I put in everything except the active x after uninstalling.
Reinstalling Windows XP
By wulf109 in forum ComputerReplies: 17Last Post: 2nd Apr 2012, 19:52 -
Reinstalling windows vista
By Sportster Freak in forum Newbie / General discussionsReplies: 2Last Post: 17th Mar 2009, 23:23 -
Question on reinstalling XP.
By dimtim in forum ComputerReplies: 3Last Post: 19th Jun 2008, 08:02 -
reinstalling svcd2dvd
By marcusden69 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 16th Apr 2008, 07:25 -
Uninstalling or reinstalling nero
By b3cko in forum ComputerReplies: 3Last Post: 10th Jan 2008, 09:37
