Hi,
I am new to this forum please pardon me if i sound stupid.
My Story
I went to my cousin house he showed me his wedding film i saw his wedding film before which was had too much brightness and colour wasn't right but now he caputred it or edited it using some program which looks like HD Quality dvd now. I was wondering hows he done it. Can that be achieved using just software or did he recapture it using better capture card and then converted it into DVD. (He got his wedding done by some guy he knows before he recaptured or edited it himself). I asked him about he has done it but he didn't tell me what he did.
I really want to learn how to do that i currently have Sony Vegas and Adombe premiere softwares and PC spec Amd athlon (tm) 64 X2 Dual Core Processor 4200
2.21 GHZ, 1.00 GB of RAM
I don't know how to get details of graphics cards or other pc details you may require to help me can you also post how to get detailed Pc information. thanks. Back to the topic i have good graphics card i am sure because i have recorded stuff off my vcr using Wintv software. Quality of the video captured from vcr tape is okay but not too excellent.
My wedding dvd is also has too much brightness and colourfull i gave my friend wedding tapes he converted them for me but quality is okay but too much brightness and colour i am sure i can improve this like my cousin did he completely changed quality of his wedding film. If i need to buy better graphics card i will and memory upgrade etc.
Now i want to show him i can do it too but without his help. First i guess you guys need my Pc details what spec i have in details can you guide me to program which tells you in details how fast his your pc and what graphics cards etc i have.
Thanks guy please reply back. Thanks in advance
You can enhance video such as adjust the brightness, colors, noise removal etc. You can't do what you describe and go from garbage to HD.
What is the most original source you have? VHS , mini-dv, DVD? -
My original source is VHS which later converted by friend to DVD. I am attaching file which tells you everything about my pc details speed, dvdrewriter etc. Please describe more what program do i need to adujust brightness etc. Thanks for reply.Originally Posted by thecoalman
my%20pc.txt -
Being that VHS is analog its best to fix these issues prior to capture. Starting with a good VCR and capture card is essential, see the restoration forum for more info.
You computer specs are really irrelevant except the capture card, Premeire and Vegas can both adjust brightness, can't help you there cause I have neither.
What card are you using to capture now and what format? -
Graphics Card Manufacturer Powered by ATIOriginally Posted by thecoalman
Graphics Chipset RADEON X550
Bus Type PCI Express
Current Bus Setting PCI Express
Memory Size 256 MB
Memory Type DDR SGRAM / SDRAM
Core Clock in MHz 398 MHz
Memory Clock in MHz 196 MHz
Primary Display Yes
This is the card i use to capture video and it captures in MPG format. At the moment i am using RF lead to connect my vcr to pc but will get svideo adapter which might help me capture better. What do u think? -
Try www.digitalfaq.com for directions for capturing to AVI using HuffyUV , from there you import into Virtualdub and use many filters.
horribly bad wedding video
By greymalkin in forum EditingReplies: 26Last Post: 23rd Mar 2011, 23:09 -
Wedding video
By kj1983 in forum EditingReplies: 12Last Post: 9th Oct 2008, 13:12 -
Help, I have too much Equipment Wedding Video
By HeidiSchold in forum Capturing and VCRReplies: 8Last Post: 20th Nov 2007, 14:17 -
I am going to be doing my first wedding on Video
By silentarts in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th Nov 2007, 10:56 -
Wedding Video Editing
By producertravis in forum MacReplies: 11Last Post: 7th May 2007, 18:38
