how would i put the srt file as internal? for some reason i can only put it as external, so the subs dont come out. is this program bugged or something? thanks
Do you want permanent subtitles in the picture? When you test the dvd you might have to manually enable the subtitle track and if you are playing the dvd on your computer don't just play the vobs but open the video_ts/video_ts.ifo with a software dvd player.
srt and convertxtodvd
By natty in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2011, 11:45 -
Convertxtodvd Burning Mkv files with Sub
By alicy in forum Authoring (DVD)Replies: 6Last Post: 31st Aug 2010, 23:29 -
cannot delete files in ConvertXtoDvd folder
By ladysox in forum Newbie / General discussionsReplies: 7Last Post: 4th Feb 2008, 10:51 -
Converting multiple files with convertxtodvd
By aruwin in forum Video ConversionReplies: 6Last Post: 29th Jun 2007, 04:27 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16
