is it possible to put a srt file in dvd lab pro? how would i do this?
Double click on the subtitle track(Sub 1) and click on Import.
i converted the srt to sp1 but the sub is still not showing am i doing something wrong? help please. thanks
Baldrick gave you the right instructions - just load your SRTs into DLP using the import function on the subtitle edit screen. Once you compile the DVD you will have to use the subtitle button on your DVD remote unless you have made them turn on by default, or created a menu to switch them on.
Read my blog here.
ok i got it now. i have 2 srt files, can you comebine them using dvd lab pro or do i need to use another program for this?? thanks
Are they two parts of the same movie, or two tracks ?
If they are two separate tracks, just add a new subtitle track and import the second srt file in the same manner as the first.
If they are part of the same subtitle track, use Subtitle Workshop to join the subs, then set the beginning of the second set to match the time it already starts, plus the length of the first part of the movie. Subtitle Workshop will reset the timing to match the shift.Read my blog here.
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 00:56 -
Help with DVD-lab PRO.
By angles in forum Authoring (DVD)Replies: 2Last Post: 3rd Jan 2010, 17:19 -
Hwo to I put srt files with Mkv2vob?
By Peterrrrr in forum Video ConversionReplies: 0Last Post: 23rd Nov 2008, 11:30 -
Help with DVD-lab pro
By Jack the Ripper in forum Authoring (DVD)Replies: 1Last Post: 4th Dec 2007, 07:21 -
Vob File has a aspect ratio of 704X480 in Dvd Lab Pro.
By mlong30 in forum Authoring (DVD)Replies: 4Last Post: 16th Jul 2007, 23:24
