I get this message
Error ID = 0xC00D1199, Condition ID = 0x00000000
What does this mean? Do I need to download some sort of codec?
divx and quicktime didnt work.
thank you
Results 1 to 9 of 9
...when doing what? Getting the message from what?Originally Posted by jyeh74
/Mats -
when trying to play the avi. i have windows media player 10
xvid codec isnt working either. -
Installed any codec pack?
May also be the DirectShow is hosed. Try reregistering quartz.dll (search this site for "quartz.dll" for plenty of info).
/Mats -
I think you misunderstod me; Codec packs are the safest way to make your system unusable.
The "too" in this sentence indicates you've tried other codec packs too? If so, that's probably the root of your problems.tried this too www.xpcodecpack.com
/Mats -
too many codecs can make it not work? its impossible to figure out which one i need then?
You bet!Originally Posted by jyeh74
Been there, done that. Never got my system back 100% until I reinstalled Windows, in fact. You can try Codec Sniper and other apps of the same vein, but they require you to know what you're doing. Start by uninstalling all codec pack(s) you may have installed. Then use Codec Sniper or similar app to remove what the uninstall has left behind.
All you need for 95% of all video playback is ffdshow. Add QuickTime Alternative and Real Alternative, and you're pretty much covered. If you find a file that wont play, use GSpot to identify what codec it needs, download and install that and only that codec.
/Mats -
Do not install ffdshow ... it will mask the issues that should be solved first ... always .
0xC00D1199: Cannot play the file
Windows Media Player cannot play the file because:
1) You are trying to play a file that is NOT supported by the player.
2) You are trying to play a file that the player DOES support , but the file was compressed by using a codec that is NOT supported by the Player.
3) You are trying to play one part of a multipart file. Use a newsreader or other program to combine the files, and then try again.
4) The file type is supported, but you are trying to play it in a way that is not supported by the Player. For example, you may have attempted to drag a DVD file with a .vob extension from a DVD to the Windows Media Player icon.
Supported files types in Windows Media Player are:
Music CD Playback (CD audio) .cda
Audio Interchange File Format (AIFF) .aif, .aifc, and .aiff
Windows Media audio and video files .asf, .asx, .wax, .wm, .wma, .wmd, .wmp, .wmv, .wmx, .wpl, and .wvx
Windows audio and video files .avi and .wav
Windows Media Player skins .wmz
Moving Picture Experts Group (MPEG) .mpeg, .mpg, .m1v, .mp2, .mpa, .mpe, .mp2v*, and .mpv2
Musical Instrument Digital Interface (MIDI) .mid, .midi, and .rmi
Microsoft Recorded TV Show .dvr-ms
AU (UNIX) .au and .snd
MP3 .mp3 and .m3u
DVD video .vob
Macromedia Flash .swf
*To play .mp2v files, you must have a software or hardware
DVD decoder installed on your computer.
Uninstall xvid codec or codec packs including it , and restart pc .
Install codecs as individual codecs only when required ... in this case , reinstall just the xvid codec .
This program helps with directshow issues .
http://paul.glagla.free.fr/filmerit_en.htm , download the program , and run scan , follow the web page info .
Extra
http://www.free-codecs.com/guides/How_to_install_default_codecs_in_Windows_XP_2000.htm
http://www.free-codecs.com/guides/How_to_install_uninstall_DLL_and_AX_files.htm (example refers to quartz.dll)
Unregistering and re-registering quartz.dll may not work .
Agree with mats.hogberg
I had 2 issues , in directshow filters , one audio , one video .
Used tool to repair sellected , broke 100+ out of 348 .
Ran process twice more (none sellected) ... all fixed on second run .
Almost wipeout time .
avi won't play
By fabre in forum Software PlayingReplies: 2Last Post: 24th Aug 2011, 23:26 -
cannot play avi
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2010, 21:48 -
data avi .hdtv.avi-fqm.wont play on set top recrder
By xbill in forum Newbie / General discussionsReplies: 3Last Post: 15th Jul 2009, 14:55 -
How to Play avi files
By drstew in forum Software PlayingReplies: 21Last Post: 30th Mar 2009, 12:15 -
play AVI on tv
By protectyanek in forum Portable VideoReplies: 4Last Post: 21st Jan 2009, 22:41
