I've got a WMV HD movie file. It plays just fine in Windows Media Player, but if I try to skip past the half way mark I get an error and the video stops. I can skip with no problems any time before the half way mark, but anything after the video won't allow it.
The strange thing is the video will actually "play" past the half way mark. The movie will play to the end, just as long as I don't try and skip into the second half.
When I get the error from Windows Media player, the help button sends me to this website:
http://www.microsoft.com/windows/windowsmedia/player/webhelp/default.aspx?&mpver=11.0....nalid=80070057
I've tried this on other PC's and it's the same problem. The file does play and skip just fine in VLC player, but not Media Center.
I'd really like it to work with media player cause I want to be able to stream it to my Xbox360. Which by the way has the same problem, skips just fine until the half way mark. After that the movie just freezes on a black screen on the tv.
Any help would be great, thanks.
Typically when files won't search/skip, it's because the index is corrupted. Take a look in the Tools section, and there used to be a few guides.
Google is your Friend -
Thanks for the reply.
I seperated the audio/video, then rejoined them again using windows media encoder programs. The file now works perfectly. -
WME probably could have fixed the file without demuxing, just opening the file and resaving it. You can sometimes fix avi files the same way using VirtualDub.
Glad you got it to work.Google is your Friend
.mov files play in slow motion or skip
By wonderkev in forum Video ConversionReplies: 2Last Post: 4th Feb 2010, 12:54 -
mux 5.1 ac3 into wmvhd?
By nick101181 in forum AudioReplies: 5Last Post: 27th Jul 2008, 15:04 -
FLV files play jerky/skip every few frames
By Madasarat in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2008, 02:20 -
WMVHD Playback problem on a particular video
By huthmakerj in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 10th Jul 2007, 15:41 -
converted vob files play on computer fine..skip when burned to dvd
By cduval04 in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2007, 19:26
