I have a video clip that has interlacing artifacts due to pulldown. I want to make a cut of a segment of it and then export it, totally unchanged. In other words, I don't need to blend the frames or anything, I just want to export it so that it remains exactly the same. It seems like it would be straightforward, but I am having a lot of trouble doing this because Premiere Pro 1.5 seems to really want to deinterlace it. When I make a file where I DO NOT check the "Deinterlace Video" box, the subsequent file is unplayable. It causes Premiere and window's media player to crash. When I check the deinterlace video box, I can make a playable file, however, Premiere processes the video (obviously deinterlacing it) and the file that gets made has a repeat frame every 5 frames. I do not want this. Does anyone have any idea why this is happening and what I can do about it?
I am using these settings to try and export the file:
File type: microsoft avi
Compressor: Huffyuv v2.1.1
(The frame rate and everything else I've set to match the original file)
Rendering options: I have tried Lower field first, Upper, and No Fields, all have the same problem.
try to fix everything u need to fix in virtualdub (virtualdub mpeg2 seems to work nicely for pulldown i heard)
Then try to frame serve the file with virtualdub's frame server(file>frame server)
change the extension .vdr in .vdr.avs
of course you need avisynth installed
But i don't know if premiere pro accept avs scripts
Exporting problem and im in a hurry pls help
By HaaL in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 17th Jun 2010, 19:26 -
exporting a captured image as a JPEG file
By altagracia in forum Newbie / General discussionsReplies: 3Last Post: 8th Nov 2009, 21:59 -
Mpeg file size balloons after exporting as FLV or MOV?
By jjachin in forum Newbie / General discussionsReplies: 2Last Post: 16th Jul 2009, 16:56 -
Youtube problem - Exporting from After Effects CS3
By slc2008 in forum Video Streaming DownloadingReplies: 0Last Post: 12th Aug 2008, 09:22 -
Quicktime Problem: Playing and Exporting
By hzgg2 in forum Video Streaming DownloadingReplies: 1Last Post: 20th Jul 2008, 15:48
