Hello everyone
I recently purchased this dvd player, http://www.ebuyer.com/UK/product/124908
I have tried dvds and they have been as good as I can expect, good audio and picture.
But when I put divx,xvid etc files onto dvds and play them on that dvd player, the picture seems perfectly fine but the audio is extremely low and I cannot increase this with the volume control.
I have looked over loads of different guides and none of them have worked, I have tried increasing volume via virtualdub, it increases but the quality goes down dramatically and seems laggy. I have done compressions with the "lame codec", I have tried goldwave and everything.
But nothing seems to be able to increase the volume while keeping a good playback.
Could yous please help me as ive been trying to sort this for hours now without luck, and have wasted too many dvd-rs.
Thanks alot and if you have any questions, I will reply quickly.
Try this little script out to raise the gain on your AVIs.
https://forum.videohelp.com/topic314909.html
The other option is to look for a firmware update on that player. -
I downloaded your program and then burned the new video file but it was just the same volume on the dvd player.
I am using nero and buring as a data dvd.
I cannot find any firmwares for that player.
thanks for the help. -
That's friggin odd. Maybe it can handle AC3 audio better. Try my 2.0 to 5.1 upmixer script.
Read the first post. You'll need to install Avisynth and have .NET 1.1 or greater installed.
https://forum.videohelp.com/topic326127.html -
ok done that, it gives me an extra audio file seperatly.
So there is a new audio file without video and there is the original video file I put into the folder.
What do I do now? -
nvm my last post, got it.
I got it to work, I just changed it to wav then added it on virtualdub.
Thanks very much friend for helping me, your a great person.
peace.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
[SOLVED]Audio won't play for an AVI file in my standalone DivX/XviD player!
By =CrAzYG33K= in forum AudioReplies: 4Last Post: 13th Oct 2008, 09:32 -
Is this DVD Player can play Divx or XviD?
By php111 in forum DVD & Blu-ray PlayersReplies: 19Last Post: 6th Oct 2007, 08:29 -
Best Divx/Xvid DVD Player!!!
By SIRCOOKS in forum ComputerReplies: 10Last Post: 23rd Aug 2007, 11:49 -
DivX/XviD file on DVD player
By Bizouman in forum Video ConversionReplies: 4Last Post: 4th Jul 2007, 03:36
