Hi Guys, not posted for a while, but could do with some help.
I had to do a full system restore and lost a lot of by set up.
Somehow (probably by accident) I was able to capture unlimited file size mpeg2 files. I then edited as required.
Problem is the software now wont work. So Ii am looking for reccomendations for a prog that does the following:
Free (of course!)
Captures in MPEG2
Doesn't file split
Oh BTW my card is an Aver pc203
Thanks peeps
J
Yeah Baby!
I was using the Aver software (I downloaded the most up to date version) when I download and install now all I get is the prog refuses to start or crashes seconds after launch. The only version I could get to work is the original that was bundled but it splits the mpeg2 files at 4gig. My HD that I am using for capture is NTFS, so I dont think its a system prob, rather a software one.
Yeah Baby! -
The about on the software says:
Aver TV
Version 4.31.2.3
Build with intervideo filtersdkYeah Baby!
*HELP* Capture xbox360 need advice
By trusoljuh in forum Video Streaming DownloadingReplies: 0Last Post: 7th Apr 2010, 14:32 -
Video Capture Advice
By Windu in forum Capturing and VCRReplies: 6Last Post: 15th May 2009, 11:30 -
MiniDv Capture Advice
By afoote@acslink.net.a in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 13th Nov 2008, 06:22 -
capture advice
By atvmxr in forum Capturing and VCRReplies: 4Last Post: 10th May 2008, 18:32 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 19:18
