I have downloaded some flv files of classical music and found major differences in the sound volume among the files. It is awkward to have to change my volume control constantly during playback. I tried using mP3gain but it interfered with the video portion of the flv files. Is there a relatively simple way to normalize the sound portion of the flv files without affecting the video portions so that use of a volume control on playback is not necessary?
You can do it, it'll be tedious, however. Classical music, which relies on wide dynamic range is not going to respond very kindly to any kind of normalization or peak limiting. As long as you can live with the fact that your end result will sound a lot like mono music coming out of an FM radio, you can try the following:
This process will convert the flv files to low res xvid/div AVI files, leveling and normalizing the audio.
Down the following app and unzip
http://www.savefile.com/files/848905
Place .FLV files into same folder as the unzipped files. Click Flv_gain.bat file to start conversion.
When done, normalized Xvid/Div AVI files will be located here
I followed the directions as given and it worked beautifully. The new filesize was 3 times larger, but I can live with that. Thanks for your help.
How do you edit VOB files from DVDShrink to mute same audio portions?
By soundoff in forum Newbie / General discussionsReplies: 3Last Post: 11th Mar 2012, 19:58 -
Annoying 'gap sound' when joining flv files
By KeyMs92 in forum EditingReplies: 2Last Post: 17th Sep 2011, 19:31 -
mkv video audio normalization / post-processing audio normalization
By o6uoq in forum Newbie / General discussionsReplies: 6Last Post: 5th Aug 2009, 00:17 -
.wmv sound normalization
By prince21 in forum AudioReplies: 1Last Post: 17th Apr 2009, 04:53 -
No sound on .flv files in MPEG streamclip and others.
By seb100 in forum MacReplies: 2Last Post: 29th Oct 2008, 11:26
