Downloaded SUPER after reading all the praises heaped at the program so I could convert a .MOV video file into an MPG or WMV. Didn't work.
In fact, I couldn't get it to convert it in to anything. It is a legit file. Just wanted to convert it to a format that's easier for our worship software/system to use.
Any ideas or help?
I AM a newbie, so please use simple terms and instructions. Thanks.
pastor sam
	MOV is an apple format, licensed and used in many cameras
 if the file is the lastest incarnation, you might need QT pro7, in order to convert it.
 or you can try "quick time alternative"
	Just the latest quicktime player or the alternative is required for mpeg streamclip to work.
 Mpeg streamclip > input mov > output dv avi ... anything else might need secondary conversion
	In SUPER (not that I'm recommending it, here), did you have Use DirectShow checked? In that case, conversion would be dependent on whatever DirectShow filters you have installed on the system (and therefore, you'd need an up-to-date Quicktime, probably Pro). Also, you can try telling it to use mencoder instead of ffmpeg, or vice versa. If cameras add ten pounds, why would people want to eat them?
  Mov file with mono audio plays silently: fixed by opening SuperBy aslaksen in forum Video ConversionReplies: 0Last Post: 7th May 2010, 20:35
  Trouble with MP4 and MOV formats.By fesmitty77 in forum ffmpegX general discussionReplies: 5Last Post: 10th Dec 2009, 15:21
  mencoder wont convert the complete file, mov to avi|movBy bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 08:42
  Trouble converting m2ts to either WMV or AVI using SUPERBy Royksoap in forum Video ConversionReplies: 1Last Post: 31st Jul 2009, 14:54
  Trouble downloading Super 1By donkeyking in forum Video ConversionReplies: 5Last Post: 6th Jul 2007, 02:21
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
