Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Jun 2007
    I have vts files , and here is some info i got , but I don't know what to do to make the DVD.
    Image: PAL
    Language: English, Spanish , French
    Subtitles:Spanish, English, French, Portugués, Danéish, Norvewian, Suedish, Holandés, Finish, Árabian
    DVD9 => DVD5 With: DVDDecripter + DVDRemake + DVDRebuilder + HC
    BItRate:
    Reduction lavel for DVD-5: 83,1%
    Overall Bitrate : 3.921 Kbs
    Space for video : 3.590.848 KB
    HIGH/LOW/AVERAGE Cell Biterate : 5.091/600/3.921 Kbs
    How do I make it region free or NTSC ? , or will it just play on my home player ?
    Any Guides for this?
    Thanks,
    Steven
  2. How do I make it region free or NTSC ?
    It comes out of DVD Decrypter as all-region. You make it NTSC with great difficulty, and not by using DVD-Rebuilder for the job. You'll have to do it on your own. Using Avisynth frameserved into HCEnc is one way. The PAL DVD may play in your home player if your home player can do the PAL2NTSC conversion. Look either in your player's manual, or in the DVD player database on this site. Here's some more information about PAL2NTSC:
    https://forum.videohelp.com/topic228149.html
  3. Member steveryan's Avatar
    Jan 2003
    Manchester
    It's already a DVD5, burn the image with ImgBurn. If you want to convert to NTSC then read https://forum.videohelp.com/topic228151.html
    He's a liar and a murderer, and I say that with all due respect.
  4. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    It is very likely already region free. Any time you decrypt a DVD, the software removes the region coding and you would have to add it back in if you really wanted it.
    But seeing that is a PAL format, then you would need to convert to NTSC. For those type of framerate conversions, take a look at these guides: https://www.videohelp.com/convert#4;41 Which one you use depends on the software you have available
    Unless you have a PAL capable player, no, it won't play unless it's converted.
    If it's a complete DVD, then it can get complicated, especially if you want to preserve the the menus, etc.
    If you just want the main video, then it's not so hard.
    Jun 2007
    ok , I understand.
