I have some dts dvd collection which is having X-rated scenes.
I need to edit them and make a “clean” dvd by re-authoring, which we can
Watch all family members together without hesitation ( including kids)-
so how can I edit them keeping Multi audio (dts,dolby digital together)
Results 1 to 11 of 11
DVD Shrink in reauthoring mode. But you will lose the menus but you can keep all audio tracks.
Thanks for you quick response.
DVD Shrink doesn't have editing capabilities, I need to cut edit video (remove some x-rated scenes from the video and re-save them) by keeping both audio (dts and dolby digital) normally video editing software doesn't have capabilities of re-saving multiple audios ..thanks -
DVDRemake Pro can do almost anything (with some experience). You can even split cells at desired point to remove (hide or delete) video fragments. Not as simple as re-authoring but keeps all original streams and menus (also editable). Allows to combine material from different DVDs (by title sets, program chains etc.) and even author manually from scratch if necessary. It is actually much more than it shows in its own help file and custom guides.
Use the reauthoring, see guide in the post above.Originally Posted by live4fun
Hi everybody,
sorry for the late response.
I have tried to cut edit using remake Pro on my friend's pc..it seems to be dificult as
when we split cell and hide one part the other part of cell also missing when finish re-authoring.(some times I need to cut few seconds only from the video OR from one big cell)
Let me try DVD shrink today. any other commercial editor ( easy to use) can u suggest?
[/img] -
VobBlanker (freeware) can do the job. You can make as many cuts as you like, but only one per cell. If you need to make more than one cut per cell, you'll have to process it with the one cut, before going back to do it again.
Open the DVD in VobBlanker, highlight the video you'll be working with so it appears in the lower screen, highlight it in the lower screen, and hit "Cells" to the right. In the new screen, highlight the cell you want to cut a piece from, hit "Prev/Cut" to the right, and cut where you want. It's pretty self-explanatory, but there's a lot more information in the included help file. -
I've just tested it and couldn't find any bug (v.3.5.3), everything not hidden is in its place after test export.Originally Posted by live4fun
You can even split a cell the desired number of times without a problem. Then you can hide any block created by splitting. No frame accuracy of course (splitting is performed by VOB units). -
hi everybody,
I tried DVDshrink in author mode but it has only triming option,
not cut edit.
vob blanker has option and we can edit one part per cell.
Can’t do more than one edit per cell and not easy to learn also.
it seems to that DVDRemake could only perform better and I have to behind
that software only.
Which do you prefer - Dolby Digital or DTS?
By yoda313 in forum PollsReplies: 48Last Post: 17th Apr 2014, 23:49 -
Difference Between DTS 5.1 & Dolby Digital AC3 5.1
By dorababu in forum AudioReplies: 8Last Post: 31st Mar 2013, 22:31 -
Is Dolby Digital HD/DTS HD on Blue Ray better than Cinema sound?
By peggypwr1 in forum Newbie / General discussionsReplies: 4Last Post: 21st Sep 2008, 00:32 -
Select Dolby Digital 5.1-ch, DTS 5.1-ch or both?
By coody in forum DVD RippingReplies: 6Last Post: 17th Feb 2008, 21:22 -
Does Divx contain the Dolby Digital and DTS sound.
By sam9s in forum DVD RippingReplies: 8Last Post: 11th May 2007, 16:37
