I have two avi's that I dl but the audio is already out of sync. The first file is fine, but 1/2 way it loses sync. The second file is out of sync all the way through. It's off by like a second or less. Is there a way to fix it without the original source?
I'm not an expert on this, but I do believe you can fix it with VirtualDub, you can split the Audio and Video and then recombine them into a new file with the sync you want.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
