I am tyring to set up a system where I can apply the same chroma key to a large amount of clips (hundreds of short clips).
I need to create an alpha channel so that when I compress it to flv it retains the alpha channel.
Keying in final cut pro is tedious. I have the keylight plugin for After Effects, which is incredibly effective, but I can't figure out a quick way to apply it to all the clips. I'm not too familiar with after effects, but I don't believe there is a simple way to do this.
Ideally, there would be a command line tool I could use. Or someway to add a filter to squeeze or compressor. Does anyone have any suggestions?
				Results 1 to 1 of 1
  Complex chroma key matting problemBy Morality124 in forum EditingReplies: 33Last Post: 7th Nov 2010, 16:36
  Can Premiere CS4 do quality chroma key? I can'tBy MAtkins in forum Newbie / General discussionsReplies: 35Last Post: 26th Mar 2010, 03:49
  My first attempt at a bluescreen chroma keyBy CogoSWSDS in forum EditingReplies: 4Last Post: 16th Apr 2009, 23:11
  Need advice on batch editing a large number of clipsBy clarkkent in forum EditingReplies: 6Last Post: 6th Apr 2009, 16:57
  An alternative to the Chroma Key.By fr4nk in forum EditingReplies: 10Last Post: 8th Jun 2007, 14:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
