Can anyone suggest an easy to use MP4(PSP) video editor
Tried them both and they wont do what i need, heres my problem, i use DVD shrink to rip a segment from a DVD, I want to edit that segment so i can cut out a section i dont want, (eg adverts on a tvshow) then i want to convert that video to play on my PSP. CLONEDVD MOBILE is great and is an all in one tool for the JOB, BUT wont allow the editing i want, However VIDEORedo has just the editor i need, but the edited output file is not recognised in CLONEDVD Mobile. SO how can i edit the original ripped DVD file frame by frame. or in other words i need a frame by frame editor that can chop out sections of the original VIDEO_TS folder contents
thanks for any advice,
Funny , dvdshrink can do that in reauthormode .
Drag clip from right to left .
Highlight the clip .
Hit the chapter button just up to the right (set start / end frames) .
Move end marker back towards front .
Click on the little button on time line .
Use left or right keys , to land on frame .
Click button to save .
Repeat steps , building it piece by piece until done .
Hit backup .
No more junk .
Clonedvd mobile picks up from there . -
dvd shrink isnt as accurate, for what i need to do, the method you suggest doenst go frame by frame, it moves it 15 frames at time, and im afraid im a bit of a newbie and cant get the hang of avidemux, thanks for tryin though, does anyone know of a prog that wil just simply edit frame by frame and save it in the same format
Convert VOB file to MP4 (PSP)
By HunterD in forum Video ConversionReplies: 4Last Post: 5th Mar 2010, 02:39 -
PSP(MP4) Video Conversion...
By Nizomi in forum Newbie / General discussionsReplies: 7Last Post: 11th Oct 2008, 03:53 -
mp4/psp sounds problems
By Nick1982 in forum Newbie / General discussionsReplies: 1Last Post: 21st Jul 2007, 15:22 -
PSP video file editor
By efiste2 in forum Portable VideoReplies: 1Last Post: 27th Jun 2007, 18:07 -
psp and mp4's
By zinc in forum Portable VideoReplies: 4Last Post: 19th Jun 2007, 13:50
