hello
can you tell me please how to compare sound (music files) and say whats better quality?
thanks
Results 1 to 11 of 11
Listen to them.
You can compare file format, audio bitrate and such but it doesn't really tell the quality. -
ears for sure cant distinguish
there are some things that are sure, eg
1) 320kbps is better than 256kbps
2) lossless codec is better than mp3 codec
I need more like the above, eg, which codec is better than other, VBR is better than CBR, etc
is there a list/tutorial/something? -
Sure, PCM is better than MP3, but it takes up a lot more space.
And unless your source audio is high quality, it doesn't make much difference what format you convert it to.
I favor AC3, especially 5.1 or better for good quality in a fairly small space. For more compaction, look to Ogg. It has a lot of potential. There are other audio codecs which may be even better for high compaction and small space, but most of the time, for compatibility, you need to stick to 'mainstream' formats.
For AVI type video (Xvid, etc.), Aud-X is an interesting option, instead of MP3.
Generally, higher audio bitrates are better, whatever format. But at some point you sacrifice video quality if you use PCM and have a limited room for video/audio. If you have a short video and can afford the space for PCM, use it.
But bottom line, as Baldrick says, your ear is the best judge of quality.
thanks
I am interested in audio onlyOriginally Posted by redwudz
is there a nice comparison table, tutorial, reference,? -
this may help
http://www.digitalradiotech.co.uk/bitrate_vs_quality.htm -
if you want the best sound, use a FLAC encoder, none of the quality is lost although the file size is around 10mb per minute
thanks
fyi I found this
http://wiki.hydrogenaudio.org/index.php?title=Lossless_comparison
if you have more, please post -
Audio is a broad topic. Maybe you could talk about the source format/quality and how you want it played (e.g. web stream, ipod or theater performance) ?
http://www.kiva.org/about -
You can use an ABX program. See http://www.pcabx.com/ for one such program.Originally Posted by ecos
J -
I thought "10MB per minute" meant "16-bit stereo 44.1kHz PCM".if you want the best sound, use a FLAC encoder, none of the quality is lost
FLAC usually is around 6 MB per minute, IIRC.
Recording High Quality Sound on PC
By evil nemesis in forum EditingReplies: 11Last Post: 25th Feb 2012, 14:36 -
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 21:10 -
Very Poor Video/sound quality
By mikey56hernandez in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2011, 20:27 -
Encoded BD movie sound quality
By GeeForce11 in forum Blu-ray RippingReplies: 0Last Post: 15th Dec 2008, 08:05 -
How to improve the sound quality of this video?
By awaisuk in forum EditingReplies: 2Last Post: 19th Nov 2007, 22:15
