Using WinXP.
I converted one of my drives to NTFS to allow for larger file sizes and then found that Tmpgenc wouldn't open any AVIs.
Does the prog not support NTFS ?
I reformatted the drive back to FAT32 and the prog opened the files OK again.
Am I stuck with the smaller file size limit and will have to author smaller clips and then join them together with Tmpgenc ?
Chris.
I don't think it's the NTFS that is the problem, but the new "security" in the NTFS on WindowsXP, which causes incompatibility with ALOT of programs, if you have Windows2000 which also has NTFS, it will not have this problem.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Blu Ray file system on DVD-R media ?
By HDVguy in forum Authoring (Blu-ray)Replies: 24Last Post: 19th May 2012, 10:42 -
RAW File System
By Compo in forum DVD RippingReplies: 6Last Post: 15th Jan 2012, 09:20 -
An AVStoDVD non-starter (file-system limitation)
By Seeker47 in forum Video ConversionReplies: 9Last Post: 24th Nov 2010, 10:53 -
System.IO.FileNotFoundException: Could not find file 'D:\Polar_S2D.mpg'
By RainbowLand in forum SVCD2DVD & VOB2MPGReplies: 18Last Post: 27th Jun 2007, 16:26 -
File system for a DVD recorder HD
By csanders1962 in forum ComputerReplies: 1Last Post: 30th May 2007, 15:08
