Ok here is my situation:
I need a capture device to record video games and what not, but the problem is i have an HDTV and i am used to playing in HD Quality, i originally bought a DVD recorder to record but the video quality was horrible so i had to return it.
Is their anyway of converting basic video cables into HD quality?
I was told that an HD Tuner could do the trick, but i have no clue and dont wanna buy something if it wont work.
*Basically I think i need a capture card device were i can plug my Xbox 360 Component cables into the capture device and then the capture device will need to have component cables that i can then plug into my TV*
Also do they make HD capture devices?
Any help will be greatly appreciated.
Thank You
Closed Thread
DV capture quality sucks
By cooldude859 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 36Last Post: 28th May 2008, 15:07 -
Will AVCHD capture quality improve?
By twalkman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 6th Nov 2007, 16:13 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Problems with Capture Quality
By drxpsp9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 25th Jul 2007, 22:53 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
