Ok here is my situation:
I need a capture device to record video games and what not, but the problem is i have an HDTV and i am used to playing in HD Quality, i originally bought a DVD recorder to record but the video quality was horrible so i had to return it.
Is their anyway of converting basic video cables into HD quality?
I was told that an HD Tuner could do the trick, but i have no clue and dont wanna buy something if it wont work.
*Basically I think i need a capture card device were i can plug my Xbox 360 Component cables into the capture device and then the capture device will need to have component cables that i can then plug into my TV*
Also do they make HD capture devices?
Any help will be greatly appreciated.
Thank You
Results 1 to 1 of 1
How to capture gameplay from XBOX360 to AVERTV capture card
By Ollie999 in forum Capturing and VCRReplies: 2Last Post: 25th Oct 2011, 20:16 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
