I downloaded an AVI file (I do believe it's a divx file) and I want to use Toast 8.0 to author it to DVD. But when I try to pull the file into Toast using the Video tab, I get a message that says that the file format is not supported. Ditto trying to import it into iMovie or iDVD. So what's the best way to do this?
H777
We need a bit more info.
Since Quicktime based apps cannot handle it,
more than likely it is a codec issue.
Do you have Perian installed?
Do you have Divx 6.5 installed?
Try opening the file in VLC, and performing the Information
command to find out what it says about stream 0 and stream 1.
Once we find out what codec it needs, we can then transcode it
to DVD."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
FMP4 is an MPEG-4 flavor as encoded by ffmpeg or mencoder at one time. Try DivX and Perian components. If QuickTime won't read it, you may want to change the fourcc to DIVX and try again.
and since it is an avi, you should be able to use Divx Doctor II to do this. But installing Perian should make Quicktime handle it fine.
Urban Mac User -
1. Install Perian.
2. open file in QT Pro.
Make sure it plays fine, audio is ok, video is ok.
3. Launch Toast 8. Seelct the Video Tab. Select the DVD button.
4. Drag and drop it into the Video Tab window.
5. Insert blank disc
6. burn.
if you have problems with #2:
2a. Download Divx Doctor II from versiontracker.com
2b. Launch Divx Doctor II
2c. Drag and drop file onto DD II window, hit process (ok)
2d. once done, repeat step #2 using instead the "doctored" file.
if ok, follow steps #3-#6."Everyone has to learn, so that they can one day teach."
Urban Mac User
Converting an AVI file in Toast PROBLEM!!!!!!!!!!!
By thasco in forum MacReplies: 10Last Post: 14th Dec 2010, 11:44 -
Bad sound quality from avi's to DVD w/both Toast or XiliSoft DVD Creator?
By NoMoPackers in forum MacReplies: 7Last Post: 2nd Apr 2009, 04:57 -
Roxio Toast 8 - cannot burn an avi file. Just get spinning beach ball!
By Ivor Bigone in forum MacReplies: 10Last Post: 4th May 2008, 06:25 -
avi to dvd in toast 9
By levi747 in forum MacReplies: 4Last Post: 2nd May 2008, 22:43 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08
