it did not come with a HD (analog component) adapter or cable. I would need that to hook up to my TV. Does anyone know where I can get one for the NVidia card? Thanks,
T
i seem to recall that none of the nvidia 7000 and below cards support hdmi. only with the 8000 series did it start. could be wrong.
It's not the HDMI converter I am talking about. The card has a port, just looking like a regular 7-pin S-video port. It is supposed to output HD via RCA component video cable. I need a connector (dongle) in order to hook it up to the 7-pin port. Where to get one of these dongles?
Thanks. That seems to work. It is a UK site though, don't know if I can buy it from them. Got to be somewhere in the Statest that sells this.
Which manufacturer card did you buy?
The normal accessory set looks like this
This for a Leadtek A7300GT
http://www.newegg.com/Product/Product.aspx?Item=N82E16814122019
"S-Video" Y/C is available on the black connector (pins-1-4) and analog component YPbPr is on the green-blue-red RCA connectors (Pins 5-7)
To avoid confusion with the 4-pin "S-Video" connector, the 7-pin connector is called "TV out".
Thanks, edtv. Always liked your insightful posts. I guess I just did not look hard enough. I bought the card from Newegg, the Chaintech brand:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814145137
PC to Plasma HD TV with DVI Input Question (Nvidia 8800GT Video Card).
By Infinite_Dreamz in forum Newbie / General discussionsReplies: 5Last Post: 2nd Oct 2011, 09:28 -
How can I tell if my VGA card has TV-Out function capability
By lily083 in forum Newbie / General discussionsReplies: 3Last Post: 20th Jul 2010, 17:26 -
Graphics card for video editing. ATI or Nvidia?
By vid83 in forum ComputerReplies: 2Last Post: 6th Feb 2009, 16:29 -
Nvidia 6800 GT Video Card Problems
By theyuw in forum ComputerReplies: 12Last Post: 2nd Jul 2007, 19:54 -
nVidia 6150 motherboards and HDTV
By Robert Simandl in forum Media Center PC / MediaCentersReplies: 13Last Post: 14th May 2007, 15:11
