do you think the DV-970HD from OPPO is worth if i'm only going to use it for playing DivX?
i plan on using it on a 40" LCD (not Full HD) and i wonder if there would be any difference between this and my current $50 LG dvd player -- i really don't know if i should use the DVI, HDMI or the component input for best quality either.
also, if somebody owns this same (or another Oppo) dvd player, i was wondering how the subtitles for DivX look like (SRT files), since my current LG, when using separate subtitles, shows some big bold white letters with a huge transparent background and honestly it looks really bad.
thanks.
I have a Magnavox MWD7006 ($37) DVD/Divx player. I don't use subtitles.
The output should be HDMI for the player, if your tv has DVI or HDMI for a HD player. If your tv has only a DVI input, you could use an adapter. A HDMI to DVI adapter should work fine, but you may still have to use the components for sound.
Oppo BD-93 Anyone got one?
By oldfart13 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 22nd Nov 2010, 16:09 -
Is it worth to encode from DivX and/or XviD to BluRay?
By rocky12 in forum Newbie / General discussionsReplies: 4Last Post: 23rd Nov 2008, 11:53 -
OPPO DV-970HD HDCP Hack // OPPO 983
By Grain in forum DVD & Blu-ray PlayersReplies: 5Last Post: 26th Jan 2008, 02:29 -
Oppo 980, DivX files get frozen video at some spots
By s_poisk in forum DVD & Blu-ray PlayersReplies: 3Last Post: 16th Nov 2007, 11:30 -
Oppo Player HD-Divx Compatibility
By N8theGr8 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 24th Aug 2007, 14:34
