When I burn DVD's, I'm finding they flicker. It must be slight because my wife can barely pick up on it - but to my eyes, it's very disturbing. I can only describe the flicker as a bit like a computer monitor if the Hertz setting is too low. Another way it could be described is it's like a strobe effect (without the screen actually going black - and it's very rapid).
It's not noticeable when most of the image is still, but when the image is from a camera panning or a large image onscreen is moving, it's jittery.
I'm using Videostudio to edit, saving as an mpeg, & burning with NeroVision. Videostudio chooses by default:
Media type: MPEG 2
Video Data Rate: Variable 6000 kbps
Frame type: Frame based
Apply anti-flickering filter: Unticked
Perform non-square pixel rendering - ticked
Thanks,
Mark.
Are you starting out with DV type video? If so you should save it in that format after editing then use a dedicated DVD spec MPEG-2 encoder such as HCenc to do the actual encoding.
Also make sure you use a good DVD authoring program that does not attempt to re-encode. NERO is considered a very poor DVD authoring program. There are some freeware DVD authoring programs but one that is simple and easy-to-use is TMPGEnc DVD Author but that is a pay program.
If you are starting out with DV camcorder footage or TV captures they are interlaced so should remain that way. You are allowing VideoStudio to deinterlace. Change the Frame based setting to lower field first for a DV transfer or upper field first for a TV capture.
Richard_G, Thanks.
In your opinion, do you think the specific problem I'm having is likely the interlacing setting?
Mark. -
Almost certainly. Try re-encoding a short clip of footage leaving the interlacing, burn it to a DVDRW and check it. An interlace problem is only usually noticable with horizontal movement, a pan or someone/thing moving across the shot.
If you set the Project settings in Videostudio for PAL DVD, it should select the correct interlace settings anyway, but may ot have got it right.
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 19:01 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 08:08 -
Flicker, scanlines and non "anti-aliased" image
By F u r u y á in forum Authoring (DVD)Replies: 2Last Post: 19th Jan 2008, 01:35 -
"resume play" feature for dvds burned by dvd recorders (pioneer d
By barninga in forum DVD & Blu-ray RecordersReplies: 9Last Post: 19th Nov 2007, 02:11 -
Looking for "flicker out" transition for FCP
By ehmjay in forum MacReplies: 6Last Post: 23rd Sep 2007, 23:47
