  1. I have made a few VCDs with about 10 music tracks on them, but when I play
    them on my Lecson 900 the discs crash when they get to around track 6.
    Has anybody else experienced this?
    Do you reckon the player is a bit faulty or it could be something to do with
    the way the disc is burnt using Easy CD Creator Plat Edition? Has anybody ever seen this problem before as they play fine on my PC.
    Cheers all!
    Gray
  2. It's unlikely that your stand-alone player is at fault... There's probably something funny with how your VCD has been authored/burnt.
    It's hard to speculate on what the problem is exactly though with such limited information.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. Thanks for that Mike!
    Yeah, I think I would have to agree with you there.
    Its happened twice now and always seems to be around track 5, 6 or 7.
    I have a feeling it may be Easy CD Creator at fault. What do reckon, get some new buring software?
    Cheers!
    Gray
  4. Heres a little more info if anybody can help...
    It gets to track 6 and then just hangs there for about 30 seconds. You can hear the player trying to play it, then it just goes straight to track 9 and plays that!
    I think if you try to play tracks 6, 7 or 8 it happens and only lets you play track 9.
    MMnnn, very odd.
    Ta!
    Gray
  5. Just found this on
    here...http://www.vcdhelp.com/phpBB/viewtopic.php?topic=51170&forum=1&4
    I think others have had this problem too, its gotta be a problem with Easy CD Creator.
    Ta!
    Gray
