I'm tryiing to capture the blue screen with white DV tape graphic you see when you play back or rewind a tape in your camera
i've already tried to dub it (with RCA cables) with two DV Cameras but all i can capture is the blue screen
I really need the white tape "rolling" in there
I'm guessing that you can dump it onto a VHS deck and then recapture it...but that is the last resort
It seems like there should be an easier way to do this
Any input?
The time code appears on my S-Video output but not IEEE-1394. Is that what you see?
Just cap off S-video. If you can display time code on something other than the LCD there is no problem.
If you can't, you find a DV camcorder or player that can. (hint Sony).
Also most pro players do window dubs of TC. -
If a Sony, check the menu setting for "Display" - you can typically choose LCD Only or LCD/Video Out.
John Miller -
I don't see the timecode at all
I have a Canon XL-1 that i shoot with and a ZR-10 that i use as a deck for capturing
I'll check the display settings on both
any more hints? -
Borrow a Sony?
We used to call these "Special Defects"
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 10:30 -
Playing the tape on the camcorder only shows a blue screen.
By seven1970 in forum Capturing and VCRReplies: 9Last Post: 23rd Mar 2012, 18:44 -
Re-editing digital on-screen graphic on MPEG files saved from DVB-T
By ANOther1676 in forum EditingReplies: 3Last Post: 17th Dec 2010, 18:23 -
PC connected to LCD TV | Graphic Card Temp > 55 | TV Screen Blinking
By anoopaythala in forum Media Center PC / MediaCentersReplies: 3Last Post: 27th Feb 2009, 16:23 -
8mm camcorder tape going to blue screen every few seconds during playback
By w@ntonsoup in forum Newbie / General discussionsReplies: 9Last Post: 16th Dec 2007, 13:35
