Please help!
I am using VirtualDub-MPEG2 to get a vob file from a dvd and convert the file to avi. I compress using Divx and the file comes out fine, but I can't figure out for the life of me how to make it smaller. It's a 20 min or so clip that projects around 300+MB while its rendering at 512x384, but I want it around 120MB, at the best quality possibilty. I know the lower size you go the worse the quality, but I'm trying to fit about 13 of these onto a 4.7 disc. If anyone has this program and can help tell me how to get the overall file size down to 120 or lower, please let me know!!
File size = bitrate * running time
Use a lower bitrate. Use a bitrate calculator to figure out what bitrate you need for the file size you want.
Use multipass (two or more) encoding for best quality. Set up everything the way you want. Set Divx up for Multipass 1st pass. Save as AVI. (During this first pass Divx is only examining the video.) Go back and change Divx to Multipass Nth pass. Select the bitrate you want. Save as AVI again. -
And make sure you don't inadvertently convert the audio to PCM WAV audio.
If they're all like the first - 20 minutes and 300 MB - they'll all easily fit.I'm trying to fit about 13 of these onto a 4.7 disc.
Capturing with VirtualDub - File size 400GB and only 2 hours from old rec
By Diegovh1 in forum Capturing and VCRReplies: 15Last Post: 28th Jan 2012, 06:40 -
VirtualDub + Xvid: problem with file size in 2 pass encoding.
By marcinkk in forum Video ConversionReplies: 3Last Post: 8th Dec 2011, 15:47 -
VirtualDub -- XviD file size problem
By higgins327 in forum Video ConversionReplies: 8Last Post: 29th Mar 2011, 16:05 -
Why does XVID avi file balloon in size when converting to mpeg2 or dvd?
By im2020 in forum Video ConversionReplies: 3Last Post: 11th Aug 2010, 12:30 -
How to Reduce Mpeg2 file size without loosing quality, if possible.
By mlong30 in forum Authoring (DVD)Replies: 2Last Post: 19th Jun 2007, 08:21
