Is it possible to convert HDTV x264 MKV file to Divx retaining original 5.1 sound?
I tried Super, AutoMKV and both suggest Stereo only. Is it a limitation or what is the issue?
On a separate note, I have HDTV TV which support 1080i, my DVD player connects using composite cable to TV, which resolution do I need to choose during conversion to maximize quality?
Thanks,
G
Tried alltoavi?
You could also demux the 5.1 audio with mkvextractgui and mux it in the avi/divx using virtualdubmod or avimux gui. -
Here is info which come with file.
Title..........: Sexy Movie
Theater date...: 2006
Release date...: 23 June 2007
Language.......: English
Format.........: MKV
Video..........: x264, 1920x800 OAR, 10.4Mbps 2pass, 23.976fps
Audio1.........: DTS 5.1 1536kbps
Audio2.........: FLAC 5.1 16Bit ~ 1.5Mbps
VideoSource....: BluRay 1080p VC1 (Sexy movie DL 1080p VC1 PCM 5.1 PerfectionHD)
Audiosource....: BluRay LPCM 16bit
Runtime........: 2h23min21sec
Filesize.......: 11,9GB + extra, 1,49GB FLAC Audio
Samplesize.....: 101MB -
If you want both audio tracks, then no there isn't a single tool. You may try Avidemux, but I am not sure it will work. If you want only one audio track, maybe Super can do it.
In fact you want to convert the video x264 to XviD or DivX, not the mkv. As result you got to have an avi with DTS and FLAC (hmm). -
What do you mean by "both audio tracks"? I want just one English 5.1 audio and that's it. I don't understand why description lists 2 audios, one in PCM and another one 5.1.
In the info it is written:
Audio 1 DTS 5.1 - this is the first audio track and
Audio 2 FLAC 5.1 - this is the second audio track. This is what audio you should have in the mkv. They both can be English and are 5.1.
As for PCM this is the source from which video and audio were converted to create the mkv
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 02:45 -
Burning MKV Subtitle retaining font type style
By geneariani in forum SubtitleReplies: 7Last Post: 27th Oct 2010, 20:16 -
MKV to AVI - But retaining forced subtitles...
By peejay1977 in forum Video ConversionReplies: 1Last Post: 18th May 2010, 04:00 -
Creating a DVD from a MKV file and retaining all the audio tracks
By TioSolid in forum Video ConversionReplies: 7Last Post: 8th Aug 2008, 07:06
