Hi,
Is there anyway to burn a DVD as a data disc , similar to making a CD data disc so that the
DVD disc can be watchable in a DVD/Divx home player ?
Thanks,
Steven
Please don't hijack topics. I removed your other post.
Just burn as UDF/ISO and it should work on many divx dvd players. -
Thanks , Is there a guide on that?
I want to transfer avi , mpeg, files as data to a DVD data disc like I do when I burn them to a CD data disc.
Steven -
If you have Nero, just choose the option to make a Data Disc under the easy use GUI (I forget what they call this as I never use it) or you can select the first option in Nero for DVD which is DVD-ROM disc and just drag and drop the files you want to burn into that. I don't know how to use other burners as I use Nero when I want to make data discs. Yes, it is very similar to making a CD data disc, except if you have any files greater than 2 GB in size, you MUST burn a UDF data disc as ISO won't support that file size.
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 22:18 -
Copping Disc - Disc Data Recovery Software.
By Teac23 in forum DVD RippingReplies: 5Last Post: 1st Oct 2010, 20:06 -
Why I get a data disc every time when I burn BD-5 ?
By mahogany in forum Authoring (Blu-ray)Replies: 7Last Post: 6th Dec 2009, 03:10 -
DVD Data Disc
By DuBsTaR in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2009, 04:31 -
DVD Menu For Data Disc
By MourningStar in forum Newbie / General discussionsReplies: 2Last Post: 26th Mar 2009, 22:36
Follow Baldrick's and jman98's advice for file size/format.
