here's an example of what i mean can this be fixed and how?
1.avi
damn.ok anyway cutting it out with out losing too much?an what tools
Unfortunately, your video has too many bad frames going one by one and you can't use adjacent frames for interpolation. However, I was able to find a place for an example where just one frame 63 was corrupted and it is replaced below by repeated frame #62:
LoadPlugin("C:\Program Files\AviSynth 2.5\SpecialPlugins\badframes.dll")
AVISource("E:\My Downloads\1.avi")
BadFrames(63, blend = false)
#64 also had a small problem, so I didn't use 'blend = true' here.
You can only cut out multiple bad frames using internal Trim command. First try something like All Media Fixer for your file. -
http://www.avisynth.org.ru/badframes/badframes.html
(description)
http://www.avisynth.org.ru/badframes/badframes10.zip
(download)
For multiple bad frames use internal FreezeFrame command as manono suggested in the other thread where we discussed it.
Are these VHS tapes fixable? youtube sample included.
By kcr in forum RestorationReplies: 11Last Post: 29th Sep 2010, 07:37 -
DVD central ring is cracked - fixable?
By ecc in forum Off topicReplies: 1Last Post: 21st Jul 2009, 22:39 -
Is a U61 Error with Panasonic DVD Recorder Fixable
By wolf01 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Apr 2008, 07:34 -
Audio out of sync on MP4 file. Fixable?
By liverkick in forum Video ConversionReplies: 2Last Post: 26th Feb 2008, 14:01 -
What's happened to the coloured boxes next to latest tools?
By DRP in forum FeedbackReplies: 10Last Post: 26th Jun 2007, 13:00
